| Posted by Chuck L on December 08, 2003 at 22:39:38: | |
We've got a two-faucet bathtub, about 70+ years old, and a slow drip has turned into a steady leak, so we've been trying to replace the gasket. I've removed the faucet handle, brass collar, brass sleeve and porcelin cover, but that's as far as I can go without some advice. According to the plumbing supply shop "advisers", I should see a hex-head inside the shaft housing, and backing that off will remove the shaft and gasket assembly. The problem is: ...no hex-head can be seen inside the the shaft housing. Not even a rounded-off one. There IS a 1.5" diameter brass tube with female threads that sticks-out an inch or so from the wall, which has a lot of pipe-wrench "bite-marks". This tube surrounds the shaft at the wall. I don't want to try turning this tube, since it may be reverse threaded or something, and breaking it would mean "new plumbing". Here's a photo from another web-page, showing old faucets that look somewhat similar to what we have, but I can't see that internal hex-head in the photo. http://desktoppub.about.com/library/photos/blplumbing1.htm Is it possible that we have a faucet system that doesn't have an internal hex-head? |
