Re: Location of a thermostat
Posted by e-plumber on December 07, 2003 at 22:32:06:
In response to Re: Location of a thermostat
: We are wanting to place a cabinet approx. 18 inches from our thermostat. The cabinet would be to the left of the thermostat as you look at it. To the right, there is a door to the rest of the building and to the front the thermostat is unobstructed to 80% of the building. Will this cause any problems to the operation of the thermostat? Reply: If the thermostat was installed in that location and it worked fine, then placing the cabinet 18" away from it should not affect the operation of it. Good Luck. e-plumber
Replies to this post
There are none. |
