Re: WELL PUMP PRESSURE SWITCH
Posted by Dutchess Plumber on December 07, 2003 at 19:51:56:
In response to Re: WELL PUMP PRESSURE SWITCH
Sounds like your well tank is water logged...if its a galvinized steel tank you need to drain it down completely by shutting off the pump and refilling it to get a cushion of air .....if its a bladder tank you need to check the Schrader valve and see if water comes out ...if it does your gonna need a new tank ...alot of times the bladder ruptures and you might have air still coming out of the valve so dont be fooled ....if all else fails call a pro. lots of luck Dale
Replies to this post
There are none. |
