GAS SUPPLY
Posted by ROBERT on December 06, 2003 at 20:17:16:
IM INSTALLING A GAS LOG SET IN MY WOOD BURNING MASONARY FIREPLACE. THE QUESTION I HAVE IS SHOULD I RUN BLACK PIPE OR CAN I USE COPPER TUBING WITH FLARED ENDS. ALSO CAN THE SHUT OFF VALVE BE LOCATED INSIDE THE FIREPLACE OR OUTSIDE. THE GAS LINE WILL BE A 10 TO 15 FEET RUN IN THE CRAWL SPACE.I PREVIOUSLY CHANGED MY DRYER TO GAS AND RELOCATED MY GAS HOT WATER HEATER,SO I HAVE RUN GAS LINES BEFORE WITH NO PROBLEMS. THANK YOU
Replies to this post
