Re: pvc flange where floor meets toilet broken
Posted by Travis on December 05, 2003 at 16:40:24:
In response to Re: pvc flange where floor meets toilet broken
hey thanks I will look for this : : The pvc flange where the floor meets the toilet is broken. It is broken where the slot for the screw went on one side. We plan on puttin tile in this bathroom if this makes fixining the problem any easier. What is the remedy for this problem. I hope that it is easy since I broke the thing just ripping te toilet off the floor out of the frustration of not being able to undo a rusted bolt. Thanks in advance. : : Trav
: Reply: : There are repair kits available to fix the existing closet flange. : If it is beyond repair, you can chip away carefully at the broken closet flange hub, if you have that type and replace the complete flange. : Next time you can cut the bolts to remove the toilet and use only brass closet bolts when you re-set the toilet. : Good Luck. e-plumber
