| Posted by hj on December 05, 2003 at 13:24:48: | |
| In response to Re: Noisy forced hot water system | |
The way you would purge your system will depend on what provision was made to do it. Radiator pet cocks, purge cocks at the boiler, etc. and that we cannot determine without seeing it. With air in the system the water will not circulate properly and thus the area will not get heated. : What is the best way to bleed a forced hot water system? Ours is a two zone system and the zone located in the basement makes creaking noises and we hear water running through the pipes. It also does not heat the greatest, if we turn the thermostat up to 70 degrees it never gets passed 65. Thanks in advance!
