| Posted by hj on December 05, 2003 at 13:10:35: | |
| In response to Re: Valve Replaced and Gas line pugged | |
No way to do it. The valve replacement is not a "generic" job, so its cost will depend on the difficulty of removing and installing the new one, and the labor rates in your area. The grill plug should be incidental to the other work. : The main water valve in the basement leaks and needs to be replaced. I also want to have the gas line to the outside grill plugged. Could someone give me an idea about how much this work would cost. : I'm in the Northeast. : Thank you.
| There are none. |
