: : : : Nice picture. Where's the AAV? I hope it is not the time coming horizontally out of the vent stack. : : Reply: : : I figured you would know that I was being sacastic hj. : : The picture was meant to show the installer the correct way to install a WM drain, at least what I consider correct. Most people are eager to install an AAV because running a vent line is "impossible". : : ...The fitting on the vent is a clean-out fitting. : : e-plumber : People come here because they need advise not sarcasm. You should be ashamed of yourself. : : : : : Would the in-line vent(tudor) be placed after the standpipe and P-Trap. A drawing would help. : : : : Reply: : : : : This photo should help you do the install. : : : : Good Luck. e-plumber Cherly said: "People come here because they need advise not sarcasm. You should be ashamed of yourself." Reply: I am not ashamed of anything I post or reply to. If you read some of my many replys, I spend a lot of my own time advising people from around the country just like other posters do in this forum. If I am not sure of what their local code is, I give professional advise which would supersede their code. Occaisionally, I mix humor and sarcasm in my replys. Nothing is ever posted or replied to that is demeaning to anyone or mean spirited. e-plumber
