| Posted by hj on December 04, 2003 at 08:19:11: | |
| In response to Re: repair delta pressure balance faucet | |
The oldest ones had a spool just like the Moentrol and it was under the trim plate. It has a large nut with a screwdrive slot in it. Sometimes you can remove it and tap it on the floor. If you can shake it and feel/hear the piston inside moving back and forth reinstall it. Otherwise replace it. : : We get almost zero hot water out of the shower/tub. There is plenty of HW at the sink. What is the diagnostic procedure? Adjustments? The valve is probably 20 years old. : Reply:
| There are none. |
