| Posted by hj on December 03, 2003 at 22:52:24: | |
| In response to Re: Side flush toliet | |
I sounds like a Sloan power flush module. It can be repaired but firt you have to know what part is bad. : I purchased a used side flush toleit, the kind that flushes out the back wall and down the outside of the house. Inside The tank has no visable water, just a big black ball shaped valve that takes up most of the space.When ever it is flushed, water shoots out of the top. I know it isn't supposed to do that. Is this part replaceable, what is it called, and should I just buy a new toliet.They cost 500 and up so I'd like to repair if possiable.
| There are none. |
