| Posted by hj on December 03, 2003 at 08:19:50: | |
| In response to Re: kohlet basin faucet | |
If there is enough body under the counter to grab, hold it with pliers while you unscrew the stem nut. Those threads are no longer needed so you can damage them if necessary. : trying to remove stem/carterage on kohler basin faucet perhaps its a Alterena with a cressent spout : its a few years old(7-8) is top of the line, chrome and brass. round knobs, chrome with brass inserts on sides, looks like doughnuts stacked up, top of knob (chrome again)lifts off to expose screw that holds handle on stem. get handle off and there i am stopped : brass nut that apperantly holds stem in is smallish compared to other stems i have seen. i try undo it but the whole assembly seems to want to spin even though i tighten down the estuchion to the marble top best i could without breaking anything : under the sink its one of them faucets that hooks up with hoses to the spigot part, not a solid body : my question is to get to the carterage or washer(dont know what is in there yet as i cant crack it) am i correct in attempting to loosen that nut at bottom of handle stem? : any tips on cracking this thing? heat? wd40? strap wrench? i cant hold the body as its threaded top to bottom and would just butcher it with a channel lock : the problem is a slow drip and i want to fix. should i strap wrench it and use more force? i think its this one http://www.serviceparts.kohler.com/Pdfs/087663_8.pdf : any help is deeply thanked : dino
| There are none. |
