| Posted by e-plumber on December 03, 2003 at 06:48:38: | |
| In response to Re: Hard to Reach leaky tub drain assembly. | |
: Here is my problem. I installed a new tub and drain assembly. This is my first time doing something like this and they say you learn from mistakes. Well, I am learning A LOT. : So anyways, my drain assembly is leaking. The assembly is not easily accessible and I want to just caulk the seam that is leaking, but I can't reach it that easily. So my question is, is there some sort of nozzle I could use to get in there or is there a sealant of sort I could pour down the drain that would seal problem connection? Thanks in advance for any help. Reply: |
| There are none. |
