Re: WINTER SHUTDOWN
Posted by e-plumber on December 02, 2003 at 18:32:46:
In response to Re: WINTER SHUTDOWN
: CAN I SHUT DOWN THE WATER FROM THE STREET,AND STILL KEEP MY HEATING SYSTEM ON AT A REDUCED
: TEMPERATURE. I HAVE HOT WATER BASEBOARD.
Reply:
You can turn the thermostat as high as you want, it is a closed system, so if you do not disturb it it will remain closed while the water main is shut off.
If you don't have a low water cut off for the heating boiler, it could get permanently damaged if the heating system was to completely drain and the boiler continued to run while the main water was shut off.
Good Luck. e-plumber
Replies to this post
There are none.
