| Posted by Don Murray on November 07, 2003 at 10:16:31: | |
| In response to Re: water logged well pressure tank | |
: My well water pressure tank is water logged. It is a galvanized tank without a bladder. The tank has an air valve on it to inject air just like a tire has. How do I go about pumping the tank up and what pressure should I pump it up to? Thanks for your help. My pressure tanks air pocket is replenished by the pump cycle. There's an air control valve on the side of the tank that bleeds out excess air if it's attached float is below the adjusted level. Air in my pressure tank is pumped in whenever the pump cycles on. There's air in the pump lines because a Schrader valve lets air in the well pipe when the pump shuts off and the water settles back to it's natural level in the well. The purpose of the Schrader valve you see my be to let air into the tank when the pump shouts off. If there's not enough air in the tank it may be because the Schrader valve (looks like a tire valve core) is stuck or someone put a cap on it. The cycle goes like this: |
| There are none. |
