| Posted by Amin on November 06, 2003 at 20:45:27: | |
| In response to Re: Hot Water heater pilot light works and then it doesnt | |
Confirm there are no leaks - I have a similar problem and luckily, I heard drops ( 1 every minute) dropping onto the hot plate - leaky water heater. The handman website states, "Gas Heater Pilot Light Keeps Going Out Pilot light continues to go out even after changing the thermocouple. It works for a while with the new thermocouple then goes out and has to be relit. Works for a while then goes out again. Appears to be no disruption of the supply of gas. -->Sounds like you have a faulty spill switch rather than thermocouple. Replace the spill switch. " the url is: http://www.handymanusa.com/questions/hotwaterheaterq.html hope this helps
: : Any thoughts on what I should replace next? : No spill switch on heater.
| There are none. |
