Re: CUTTING CLAY SEWER PIPE
Posted by james dirksen on November 05, 2003 at 16:01:44:
In response to Re: CUTTING CLAY SEWER PIPE
: : I NEED TO CUT THE HUB OFF OF A 6" CLAY SEWER PIPE TO INSTALL A RUBBER BOOT TO ADAPT TO PVC. HOW DO I DO THAT WITH THE PIPE PARTIALLY IN THE GROUND WITH OUT BREAKING THE PIPE. THE EASIST & SIMPLEST WAY POSSIBLE. I like to do it the old fashioned way with a hammer and a good sharp chisel.Its not as easy as a sawsall but its a lot cheaper if you dont own an electric saw.Good luck Mike What kind of blade should you use on the sawzall?
Replies to this post
There are none. |
