| Posted by iamnotreal on October 19, 2003 at 13:53:36: | |
| In response to Re: How can I take off old toilet seat? Bolts rusted; plastic nut | |
: I've had this same problem on two separate toilets. : In both cases I used a Dremel rotary tool with one of the cutting wheels. : This worked great both times but be sure to wear : Bob : : The bolts securing the toilet seat to the bowl are rusted. I cannot turn the bolts with a screw driver. I have tried WD-40. The nuts holding the bolts on the underside of the bowl are thick plastic. I cannot turn them. I have been unable to saw through the plastic bolts. : : I would really like to take off the old toilet seat. Any help would be greatly appreciated. Thank you. i cant use the toilet my docter is saying that there is no cure. i
| There are none. |
