Re: Water Softener Drain
Posted by Richard Wagner on October 19, 2003 at 04:37:59:
In response to Re: Water Softener Drain
According to this document on the EPA site:
The wastewater from a (properly-recharging) softener should be the calcium and magnesium that were removed from the water, which can be good for plants.
The treated water in your house has the sodium/potassium in it that was bumped out by the captured magnesium/calcium. The desired water is actually bad for plants!
: : If it contains that much salt, then I assume it wouldn't be good to send it to the septic tank and leaching bed either?
: : : Chris:
Replies to this post
There are none.
