| Posted by Bob on October 10, 2003 at 21:59:29: | |
| In response to Re: ?How to replace Kohler Rialto Flush Valve? | |
: There are 3 screws inside the hole of the valve which if loosened allow you to turn the hook that attaches the valve to the toilet. Some Rialto flush valves have 3 tabs that fit into a triangular discharge opening on the bottom of the tank. It is removed by turning the whole flush valve right or left until the unit can be lifted out of the hole.
| There are none. |
