| Posted by Jan on September 30, 2003 at 19:06:28: | |
| In response to Re: Pressure assisted toilets | |
: I would like to replace an old toilet with a new Gerber pressure assited toilet. The question I have is since the pressure is built back up after the flush by the water pressure, how much water pressure is required to 'refill' the tank? : My concern is that I live in a rural area with spring feed water (great stuff) and use a pump to gain pressure. My peak pressure is approx. 50psi so I want to be sure that it will refill the toilet. : Thanks ahead of time for your help.
| There are none. |
