| Posted by j jarrett on September 29, 2003 at 11:21:17: | |
| In response to Re: Help! How do you dissolve/remove CPVC cement? | |
: : Hello! I was cementing 1 1/2" PVC sink drain pipes with CPVC cement (I think made by Oatey) and I found out days later that the joint did not hold. : : There is not enough room to cut off the section and redo it. I would like to dissolve/remove the cement from a 90 degree elbow, and reglue it. Any ideas as to how to do that? : : Thanks in advance! --Robert
| There are none. |
