| Posted by jim on September 20, 2003 at 23:23:38: | |
| In response to Re: Soaking tub | |
go to www.americh.com they make a 40"x40"x32"deep soaking tub good luck : : We are looking for a soaking tub (may be known as a seeping or Greek tub) to fit into a space no longer than 50" and no wider than 33-35". This would be a deep tub about 32" or more high, with a step inside it to sit on. Something used for physical rehab would also do, as we don't need pretty. Any idea of where to start? Kohler makes one they call a Greek tub, but it doesn't have a seat. Thank you. I think lots of manufacturers make these small tubs.The problem is theyre a special order item witch makes them expensive.If you have something very specific you are looking for you might opt to fabricate one .Allyou do is frame it out,cover it with concrete board,line it with sheet lead, and tile it.It will look great and last forever!Just a suggestion MikeStheplumber
| There are none. |
