Re: Toilet Doesn't Flush
Posted by sue on September 18, 2003 at 20:02:35:
In response to Re: Toilet Doesn't Flush
: : I'm sure this is an easy one, but my toilet doesn't flush. When I use the handle, the innerworkings seem too be functioning as normal, but the bowl just fills up to the brim and little if anything flushes out. After a while the water level in the bowl subsides... but it goes to a REALLY low level, not the standard depth it used to be at. Is this just a standard clog? What should I use to fix it?
: : Thanks,
: : Chris
: Sounds like a plugged toilet,I use a plunger that sort of looks like an acordian at the bottom,haven't had to pull the snake out in quite awhile (if you know what I mean)
Replies to this post
There are none.
