| Posted by Terri on September 05, 2003 at 09:55:49: | |
| In response to Re: icemaker failure/ need advise | |
: Unless you also have a cold water dispenser on the door, you will not know if there is water coming to the system or not. : : there is no water coming to the system. When I shut the water off I opened some taps to drain the house. : : : : : : hi folks. with the summer heat I have a sorta emergency. : : : : Last week before doing some plumbing modifications I shut both the water and power to my home.
| There are none. |
