| Posted by dennisdeg on August 27, 2003 at 23:39:47: | |
| In response to Re: dual well pumps | |
I am considering doing this same thing. Well depth is 250 feet. One suggestion was to draw from different depths. Any other conserns? : HJ, : I got the impression Rick was talking about shallow well pumps as he spoke of a check valve on the suction side. Seems to me that you could be asking for trouble trying to get two pumps pulling from
: : : I am going to install two well pumps (separate systems) on the same well. these pumps may or may not run at the same time. My question is : do I need check valves on the suction of each pump, and if so, what type do you recommend?
| There are none. |
