| Posted by hj on August 01, 2003 at 09:10:04: | |
| In response to Re: Baseboard hot water heat radiators | |
They were put in before the heating element was installed. And since the heating element is resting on its support bracket, you may have to remove it before you can replace the enclosure. : I may not be using the right terminology, but I want to replace the cover units on my baseboard piping system in the 38 year old house I just purchased. The units are installed over paneling. I removed the outer panel with little difficulty. I am having a problem with the panel that is screwed into the wall behind the pipes/fins and over the paneling. I was able to remove the screw/nails above the fins. However, there are also screw/nails underneath the fins and I cannot get to them. I can't figure out how the screws were put in in the first place. I am desperate for guidance, as this is a do-it-yourself project.
