Re: 12" rough in
Posted by Jack Orbach on July 31, 2003 at 15:50:15:
In response to Re: 12" rough in
: Debbie,
: Get the round front G-Max Toto Drake toilet.
: It will work with the 11.25" rough-in and stick out from the wall 26.5" in your case.
: : Terry, I know that you have tested many toilets in your own home. I need to replace my toilet. I want to get a pressure assisted system but the measurement from the wall to the bolts in the floor is 11 1/4". The toilet I have know is for a 12" rough. 1 plumber I spoke to told me that I have to get a 10' rough toilet but when I looked at the various sites on line like toto, kohler, american standard and looked at the spec sheets for different styles there seems to be a 3/4" space behind the toilet were as mine know is right up against the wall. That 3/4" would make up the diffrence in the rough. Plus space is an issue so anything over 28-29" long would be a problem. Can you help?
Replies to this post
There are none.
