| Posted by Ken on July 31, 2003 at 07:58:05: | |
| In response to Re: A quetion about pex plumbing | |
: The manufacturer of the Pex should be stamped on the pipe somewhere. : All Pex with copper crimp rings that I have ever worked with uses the same crimping tool. Wirsbo and Rehau use a different type of connection system and different tools. : You can generally rent the crimping tool. However, someone is selling Qest 3/4 and 1/2 crimpers on e-bay for $58.00 each. I like the Qest crimpers because they are shorter and lighter than many of the others. : Deb : The Pipewench
I'll check the pipe out as well as ebay. |
| There are none. |
