Re: shower stall base
Posted by Rughead on July 31, 2003 at 05:11:02:
In response to Re: shower stall base
Oops. It's the Tile Council of America and John Bridge's website has all the info you'll need. go down a bit on this BB and you'll find it. Cheers, Rug.
: Roger that. Had the same problem and if you're DIY inclined, you can DIY. The Tile Association of America has a great DIY booklet available online that takes you thru the process step-by-step. A bit of work but well worth the effort. Good luck. Cheers, Rughead.
: : It can't.
: : : We have a Lead Base shower stall that is tiled and the base is leaking rotted in spots. How can this be repaired without removing old base and tile
Replies to this post
There are none.
