| Posted by Rughead on July 31, 2003 at 03:52:20: | |
| In response to Re: shower stall base | |
Roger that. Had the same problem and if you're DIY inclined, you can DIY. The Tile Association of America has a great DIY booklet available online that takes you thru the process step-by-step. A bit of work but well worth the effort. Good luck. Cheers, Rughead. : It can't. : : We have a Lead Base shower stall that is tiled and the base is leaking rotted in spots. How can this be repaired without removing old base and tile
