| Posted by hj on July 30, 2003 at 14:36:52: | |
| In response to Re: No water to toilet | |
Yes, but not likely to be the problem unless it was turned off before the problem occurred. More likely is a bad fill valve in the toilet tank. : Hello, : No water is coming into the upstairs toilet. All lines in that bathroom and the one below it (including the toilet below) are fine. : No leaks in the house. : I suspect that the faucet for the water supply under the toilet is broken. Is that possible? : Thanks,
| There are none. |
