Basement Roughed in Drain removed
Posted by Les on July 29, 2003 at 23:08:50:
I am capping two roughed in basement drain pipes. As I pounded out the cement around the thinner of the two (about 2 1/2" PVC)I broke through the cement to the sand below and the tube came out of the ground. Can I just fill the hole with cement, or might this cause a risk for whatever pipe is below it? NOTE: this is not the main household stack, and there is another basement drain that is level with the floor.
Replies to this post
There are none. |
