Re: Bathroom, A/C, sink, gurgling sound
Posted by hj on July 29, 2003 at 17:55:16:
In response to Re: Bathroom, A/C, sink, gurgling sound
Maybe not. It is a function of the humidity in the air keeping the unit's drain trap full and the drain trap being the proper depth for your unit's static pressure.
: Thanks -- anything that can be done to fix this issue or minimize it?
: : The air conditioner's condensate drain is connect to that lavatory. When the blower is running, and the condensate trap is dry or inadequate, the positive pressure on the condensate drain causes air to enter the lavatory drain causing your noises.
: : : In two of my three bathrooms when the a/c is on, theres' frequently a sucking/gulping sound that comes from the sink/drain. Closing the sink helps considerably shut out the noise, but that's not really practical. What's going on, and what might be done?
Replies to this post
There are none.
