Re: Outside faucet leaks at handle when open
Posted by Bill on July 28, 2003 at 15:39:01:
In response to Re: Outside faucet leaks at handle when open
: : When we open our outside faucet, a goodamount of water leaks right out around the knob connection to the faucet. It's a 20-year-old freeze-proof faucet. What needs to be replaced and gdo I need special tools? : : Howard, : Sometimes you can tighten the nut near the end that holds the packing for the stem. : You may be able to replace the packing too. : Pliers will do for this. : Terry Terry's spot on right, Howard. The steps are as follows: 1. Remove the faucet handle by removing it's center screw. pull the handle straight off. 2. use a wrench to snug the hex-shaped piect that the stem comes through. There may be two hex-shaped parts, they both should be snug (not reefed-down-hard). 3. Test it. You can slide the handle on and try it without re-fastening the handle. This way you can inspect and admire your work! Good luck! Bill
Replies to this post
There are none. |
