| Posted by M Kirby on July 28, 2003 at 12:28:44: | |
In the last couple of months, 4 air & drain valves had to be replaced in a boiler-driven residential hot water heating system because of corrosion. Could the QEST-PEX tubing used when an addition was built on the house be causing the problem? There is anti-freeze in the system as well. |
