| Posted by Deb on July 27, 2003 at 10:51:02: | |
| In response to Re: water supply to garage. | |
: I'm adding a mudroom, garage and shop to my home. I want a janitor sink in the mud room and a hose bib on the far side of the garage. How do I run plumbing supply to these areas. The muidroom will be heated, the garage will not. All are on slab with short block foundation and walls. : Thanks, : Sam Are these rooms already added or are you planning on adding them. The water line for the mud room should be run before the slab is poured. There is no way to protect a water line in an unheated space. I would put in a yard hydrant as opposed to a hose bib on the far side of the garage. |
| There are none. |
