| Posted by Gary Swart on July 24, 2003 at 02:01:05: | |
| In response to Re: Shower no hot water | |
The problem has to be between the supply line and shower head. Check the easy first, there should be a cut off valve and it could be shut off. Other possibles are a kinked flex supply line, a clogged valve, or similar. Just a wild guess, but if the shower valve was leaking, the previous owner could have shut cut off valve so that prospective buyers would see the leak. |
| There are none. |
