| Posted by Deb on July 23, 2003 at 11:27:11: | |
| In response to Re: Pressure Reducing Valve | |
: Do I install my reducer on the main line after the cut off valve (between cut-off valve and water heater) or before the cut off valve, (between main meter and cut off valve)? Also will I have to install anything else because of water heater pressure after the reducer is installed? Thank you. You will need an expansion tank at the water heater location. |
