Re: Pressure Reducing Valve
Posted by Deb on July 23, 2003 at 11:26:33:
In response to Re: Pressure Reducing Valve
: Do I install my reducer on the main line after the cut off valve (between cut-off valve and water heater) or before the cut off valve, (between main meter and cut off valve)? Also will I have to install anything else because of water heater pressure after the reducer is installed? Thank you.
Replies to this post
There are none.
