| Posted by hj on July 23, 2003 at 09:30:18: | |
| In response to Re: Pressure Reducing Valve | |
The way you ask the question, the answer would be neither. The correct place is right after the main cut off valve, so it reduces the pressure for the entire house and the water can be turned off to work on it. : Do I install my reducer on the main line after the cut off valve (between cut-off valve and water heater) or before the cut off valve, (between main meter and cut off valve)? Also will I have to install anything else because of water heater pressure after the reducer is installed? Thank you.
