Re: Kitchen Island Drain Venting
Posted by hj on July 23, 2003 at 09:20:12:
In response to Re: Kitchen Island Drain Venting
You have answered your own questions, so your only concern should be to make sure which pipe is the drain and which the vent.
: I am doing the finish plumbing in my new kitchen island. My question is how high does the vent loop need to be and how far apart do the drain and vent stubs need to be? These dimensions are not given in any diagram I have seen. I assume the vent loop should be as high as possible under the counter? Not much I can do about the distance between the vent and drain stubs, since they are coming straight up from the slab. Thanks.
Replies to this post
There are none.
