Re: JennAir cooktop not clicking
Posted by robert on July 23, 2003 at 00:34:19:
In response to Re: JennAir cooktop not clicking
: One of my four burner gas outlets does not click when the control knob is turned on. Unit is CVG4280S : I have downloaded part diagrams and wonder if the igniter is the problem. However, the other gas burner in the same bay (the right one) does click and light fine. I am able to use the rear right burner, of course by using a match after the gas is on. Surely this is a common problem--any help is appreciated ! There are only three components to consider in the burner ignition system. they are the ignitor,the switch, and the spark module. One of the interesting things about these systems is that when any one burner is clicking they are all clicking. Try turning the burner on that does work. Then look at the ignitor on the one that doesn't. If its clicking then you know your ignitor is ok
