| Posted by Randy on July 20, 2003 at 22:00:11: | |
Pressure tank has a small puddle under it occassionly when the humidity level goes up, is it possible it is because the fittings on the tank outlet are a galvanized elbow leading to a galvanized union then to p.v.c. pipe or do you think it would be a leaky fitting joint. Thanks |
