| Posted by seemomgo on July 20, 2003 at 17:36:20: | |
| In response to Gary, here's an update... | |
My previous post said the flange was rusty. Actually, I think it is called the flange ring. It is cast iron, I think, and solidly glued to 4 inch pvc pipe. Is it OK to leave the flange ring as is since, hopefully, I'm fixing the leak? Will the rusting stop? Lastly, the ring isn't bolted to the concrete...there doesn't appear to be enough concrete to bolt into. Hopefully the new tile will help secure it. Thanks for your help. I've learned a lot from reading this board!
| There are none. |
