| Posted by hj on July 19, 2003 at 09:30:40: | |
| In response to Re: Reduce toilet flushing noise | |
A floatless fill valve may not change the noise or might even be noisier. Which noise are you referring to? That of the bowl flushing or the tank refilling? : What retrofit parts are on the market to materially reduce the noise of the toilet flushing ? Current installed units have flapper valve tank openings and a relatively common floating open and shut-valve. Can they be replaced with engineered, modern elements to reduce noise? Ball-park costs of such items? Thanks
| There are none. |
