| Posted by Ozzie on July 18, 2003 at 23:48:54: | |
Hi, I recently replaced my air tank (leak) and have now a bigger tank with 20gallon volume (about 4.5g of water capacity). My problem is the following: 1- When I open the water in house to the max flow it seems like the switch will turn off the pump and it will run out of pressure (water). I have no other problem with it in normal usage except at high flow... My tank has a 38psi pressure, cut on pressure seeme to be 39-40psi and cutoff pressure 55psi. My well pump is a 1/2 HP at 185 feet deep. Can you help me? Thanks |
