| Posted by William on July 17, 2003 at 15:17:22: | |
| In response to Re: rusty water from the well | |
The problem is that the BOSS is not big enough to remove the iron. What you need is larger unit and a professional like myself to test your water and size it according to your water. I recommend that you don't just get a quote from one source to save you money. Usually a water test is done at no charge. Take Care! Send me an email if you want more help. : The rust is from iron oxide which comes from older not daily used metal pipes that corrode from the inside out. Ask a plumber to dicconnect the pipes at the area where they are most accessible near the water softener and examine their innards. If they're rusty, ask for an estimate to trace back to where they are rust free, and replace them with new.
| There are none. |
