Re: Replacing the drain in a bathroom !
Posted by Hube on July 17, 2003 at 15:07:14:
In response to Re: Replacing the drain in a bathroom !
: I'm trying to remove the drain in my mom's bathroom. I can't get the "ring"(the portion on the inside of the sink that the drain stopper sits in) to unscrew off of the main drain. I did unscrew the large bolt from under the sink and there is some play to the top part of the drain. What is the trick to removing the rest ??
: Pls help and thanks in advance. I hope you meant you " unscrewed a large NUT off from under the sink. If you did, undo the trap, swing it out of the way and push up on the pipe that you loosened. Usually, it's just a caulk,or putty its sitting on. good luck..hube
: Matt
Replies to this post
There are none.
