Re: How to repair a caroma flush valve
Posted by Terry Love on July 15, 2003 at 23:32:44:
In response to Re: How to repair a caroma flush valve
You will note that the mechanism is held in at the top with ears.
If you gently spread apart the top, you can slide the inner part up past the "ears".
Replacement should be fairly easy with this inner mechanism out.
More pictures can be seen at the link below.
Terry Love
: Mr. Love,
: I have just purchased a Caroma toilet. No problems so far.
: But what about the future? How does one repair the flushing mechanism? I would expect that the closing mechanism would eventually leak. I can replace a flapper on a conventional toilet, but don't see how the rubber valve on the Caroma can be replaced without removing the tank and unscrewing the flush gearing from the tank. Do you have instructions for doing this repair?
Replies to this post
