| Posted by hj on July 15, 2003 at 23:16:46: | |
| In response to Re: Toilet supply line leak | |
It is probably coincidence, but some supply lines are more fragile than others. Yours may have been that version. Were the pipes a gray plastic, metal, or white flexible hose? : While we were away on vacation, both of the upstairs toilets developed a leak where the supply line joins the tank. One leak appears to be worse than the other, however, both seemed to "give out" at the same time. Both toilets were installed at the same time, (6 years ago). Can this just be a coincidence or is there a contributing factor (thermal expansion?)that I should address? My home was flooded and it would be great if I can help prevent, or minimize this in the future.
| There are none. |
